Just had a 4- wheel done at T-plus alignment shop. Vibe drove fine but steering wheel was about 22 degrees off center - one of my pet peeves.
Right FRONT camber was and is still just barley out of spec. Technician says "no adjustment for camber on Vibes" - I say "BS". WHO is right?
Question 2: how is toe-in adjusted on the rear of base 2wd Vibe? Which bolts are loosened to adjust rear toe-in?
Technician says bolts are frozen and I need to spray them with pb blaster, atf/acetone, torch & beeswax, etc.
I hope all my newby questions are more entertaining than irritating!
chiadog
