Hey guys -
Ive searched the forums, and found out that a lack of airflow thru the interior vents can be a variety of things. I wanted to post my issue and get some perspective.
I started my car Saturday and the ac was already on. The fan under the hood was going, and the ac light was also lit on the dash. However NO air was flowing from any of the vents. I turned it off and back on, still no air.
Oddly, as I was driving around, the vents magically started to work out of no where, at all speeds. But the next time I turned the car off and back on, no airflow. But this morning it was working again. It is now making a quiet humming noise as well. Any ideas on what this might be? Could it be a fuse? Or a resistor? or the motor? I dont want to pay a mechanic hundreds of dollars when I can do it myself. Thanks!
(On a side note, when the vents are not working, if you hold your hand up to a vent, you can feel the faintest of air coming thru it, and if the ac is on, its cold, and if the heat is on, its warm....weird!!!)
Thanks!
