Would a CAI help? I would say no. The system is downshifting because it feels a higher rpm is needed to keep up. The minor gains a CAI would give aren't enough to stop this from happening.vibedrive wrote:Another cruise control question:
Whenever I'm in cruise and climbing these gentle hills, the cruise kicks out the overdrive and jacks the engine rpm's up too much. This forces me to switch off cruise for hills only, and I'm able to maintain speed manually.
Would a Cold Air Intake installaion help keep cruise from jacking out the overdrive so much (since a CAI creates more hp)?
Thanks for the CAI/Cruise answers. I'm still sitting on the fence with CAI.star_deceiver wrote:Would a CAI help? I would say no. The system is downshifting because it feels a higher rpm is needed to keep up. The minor gains a CAI would give aren't enough to stop this from happening.vibedrive wrote:Another cruise control question:
Darn! Just got off the phone with K&N. Now that I am finally convinced that I'd like to jump in with this project... They do not make one for my 2005, 1.8, Base model Vibe.Brandort3 wrote:$280?!?!? I'm not sure where you have been looking, but i found mine on Amazon.com for $140.
Best of luck!
Check your brake light switch on the brake pedal and the clutch switch/pedal as well. If either are loose they could be tripping the cruise.Brandort3 wrote:I don't live in to "hilly" of an area
The vibe does not use vacuum to operate the throttle on the cruise control, it uses a electric servo. Actually, the same servo basically, that the '05 and up use to operate the throttle all the time with the fly by wire system. They simply eliminated the cable from the pedal to the servo motor and use the computer to control the servo motor based on signals from the gas pedal or cruise control, whichever is doing the work at the moment.Nitetrain wrote:Here is something to inquire about more on the faulty cruze control, maybe re-flash the CPU and Trans computers. And on that model year maybe your cruze is held stable by a vacumm hose that is leaking or old. Something to look onto or at least inspect the vacuum hoses.
E for Effort and T for nice Try,
Nitetrain.
