So, how is one supposed to tell if the stealer, ah, dealer installed the correct PCM? The old/original PCM was part #89661-01133 and the 9th thru 12th digit of the Lot #5169....both numbers indicating "replace PCM". The new/replacement PCM just installed by the dealer is part #89661-02K43, which is not on the list, BUT the Lot #1222 of the new PCM is obviously below #7226 or indicated as "not good". I can't tell any difference in the way our '05 runs after the PCM replacement.....did anyone else notice a difference in the way their Vibe ran after the PCM replacement?
http://img832.imageshack.us/img832/1082/ecm.pdf" onclick="window.open(this.href);return false;
