For a full exploration of the metric vs. imperial units fight, check out The Oatmeal.
Anyway, PCV valves. My Vibe has a 16mm PCV, I only know this because my first try didn't work with Purolater PV1066, a 3/4 inch PCV valve. So I ordered a new, 16mm sized one from BWD. P/N PCV 513. I go to put it in, and whaddya know, it doesn't fit. I go back to Advanced Auto where we discover that both PCV valves from BWD/Intermotor have the same part number, PCV513, for both the 3/4in. and 16mm. Go figure I get the 3/4in. Doing so, I also got the correct parts number for the 16mm PCV valve. They are as follows:
(May differ if you don't go to Advanced Auto Parts)
16mm size
Purolater PV1074
Fram FV406
BWD PCV513
3/4inch size
Purolater PV1066
Fram n/a
BWD PCV513
That's all I've got. Please add yours to the table, along with Vibe year, motor, transmission, and if it's a base or AWD
Thank you. I hope for this to some day be the master list of PCV valves for GenVibe.
