Servo Power
rsaxman
Servo Power
Post by rsaxman »
Hey folks,
I am trying to fix the "click" on the damper servo. I am having a little issue with unplugging the power connector. I don't want to break anything, so is there a suggested method for removing the power connector?
Thanks
Re: Servo Power
I don't remember from when I did it, but in viewtopic.php?f=29&t=37767" onclick="window.open(this.href);return false; sideshowalan said
sideshowalan wrote:There is a tab on the wire end that snaps on to the actuator end. You can pry it up from the side with a small thin screwdriver.
in viewtopic.php?f=28&t=38246" onclick="window.open(this.href);return false; Water boy posted a pic that shows the connector end of the servo
