Is there any way to display the speed on the odometer?
striker1211
Post by striker1211 »
I just read and completed the steps on using the trip button and clicking the safety belt to change the safety belt beep duration. If you hold the trip for 12 seconds and click the belt it comes up "b-on" and "b-off" and you use the trip meter to toggle. I'm wondering if maybe there are other configurations that can be changed such as making the odometer display the mph like on a ford focus. The speedometer is the only bad thing about the console because the numbers are separated by 20 mph and a dot. I find myself slipping from 25 to 30 really easy and 5 mph in the nearby school zone is a big deal. I'm about a $100 fine away from taking the dash apart and scratching in a line at 25 haha. Thanks a bunch in advance.
My Vehicle: 2008 Vibe Moon & Tunes 1.8L ATX
BlueCrush
Re: Is there any way to display the speed on the odometer?
Post by BlueCrush »
striker1211 wrote:I just read and completed the steps on using the trip button and clicking the safety belt to change the safety belt beep duration. If you hold the trip for 12 seconds and click the belt it comes up "b-on" and "b-off" and you use the trip meter to toggle. I'm wondering if maybe there are other configurations that can be changed such as making the odometer display the mph like on a ford focus. The speedometer is the only bad thing about the console because the numbers are separated by 20 mph and a dot. I find myself slipping from 25 to 30 really easy and 5 mph in the nearby school zone is a big deal. I'm about a $100 fine away from taking the dash apart and scratching in a line at 25 haha. Thanks a bunch in advance.
Umm...no, you cannot display your mph on the odometer of the Vibe like the Focus can. I have no problem maintaining the speed limit, especially in school zones. I call it...paying attention!! :shock: LOL!
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
A Psycho Martyr
Post by A Psycho Martyr »
Hey strriker, the gauge panel is actually REALLY easy to pop open.
You could get you a thin red pinstripe and cut about 1/2 inch of it ans use that as a line where 25mph would be.
Now that I think of it, I may do something similar.
HERE'S how to remove the gauge cluster
If ya have any question just post em up, plenty of us have removed ours, so you should get a quick answer
I have one of the ebay OBDII bluetooth adapters and run the Torque app on my phone to get an exact MPH readout, along with the MPG instant and average. Works pretty well for me. There are also several apps with a speedometer included that use the GPS to calculate the speed. Something to consider if you have a smart phone.
hotbug1776
Post by hotbug1776 »
Yep, scangauge or scangaugeE will work. Even corrects for tire size. Just pace with a gps and adjust.
Word of thumb, if the school zone is 20, go 15, not 24. After all, kids are quick, and, dumb, like deer. I know, I have a bunch. :lol:
A ScanGauge of either type is the way to go... I have the E, fantastic little gizmo.
Neptune/primer/rust
'21 Elantra Limited 2.0L/IVT
ColonelPanic wrote:A ScanGauge of either type is the way to go
I totally agree :D We have the ScangaugeII in both our Vibe GT's ;)
jake75
Post by jake75 »
Buy a old GPS cheap that accurately shows your speed. My brother bought a new one with lifetime maps as it didn't cost much more than updating the map on his old one from Jan. 2009. I got the hand-me down. I don't really use it for directions.
striker1211
jake75 wrote:Buy a old GPS cheap that accurately shows your speed. My brother bought a new one with lifetime maps as it didn't cost much more than updating the map on his old one from Jan. 2009. I got the hand-me down. I don't really use it for directions.
That's a good tip. I have started leaving my GPS on on long trips even if I don't have a route planned. I wish you could just update the speeds and not the maps.
journeyforce
Post by journeyforce »
A good cheaper alternative to the scangauge is the Ultragauge. It is cheaper then Scangauge (It cost me about $78($69 +7.95) ) and has a bigger screen then SGII which is good in the sunlight and also good in the night
It is a company based in the USA and I got my unit in 3 days
I wanted an OBDII gauge for my XB because the thing has only a dummy light and not a temp gauge(they removed that feature for a clock :o in the 2011 and 2012 Scion XB) and saw $150 for the SGII to be excessive for what I was looking for
Here is the link
http://www.ultra-gauge.com/ultragauge/index.htm" onclick="window.open(this.href);return false;
Here is how it came packed
It is no bigger then a standard size business card
Here are some pics of the Ultragauge in action in my XB. It has the capability to display 7 pages of 8 gauges. I only have the battery and temp gauges set up because that is all i was looking for.
Test hookup and off center
As it is just for this car, I have it running down to the OBDII connector through the gap in the steering wheel and the dash
It has a side mounted wire to connect to the OBDII connector so as to not be bumped by the drivers legs
At night:
The unit retains its memory of your settings and shuts off when the ignition is turned off and the door is open so as to not drain your battery.
journeyforce wrote:A good cheaper alternative to the scangauge is the Ultragauge. It is cheaper then Scangauge (It cost me about $78($69 +7.95) ) and has a bigger screen then SGII which is good in the sunlight and also good in the night
Not bad for the price ;) Just checked out this gadget and as an owner of the ScanGaugeII I have some pros/cons about this. Pros: better price, bigger/more displays, has timing features and more combination packages. Cons: Only one fixed color of display (blue), all buttons are on the rear of the device and are recessed. This is a huge drawback for anyone wanting to install this permanently in their dash somewhere. Also the cord only plugs into the left side. ScanGaugeII has left & rear ports to choose from. Overall I'd say it is a better bargain for your $$$. I'll find out in a few days, because I just ordered one :mrgreen: Show up at the Erie meet next weekend and we can compare the two 8-)
Got my Ultra-Gauge in the mail today :D Will let a few other GenVibers try it out on their Vibes on the way to Erie. We can compare it against the ScanGaugeII and see how it measures up.
