tune up weekend
Murdoc
tune up weekend
Post by Murdoc »
Yesterday a friend an I changed the tran fluid oil change, cleaned maf sensor and tmrw I'm taking it tmrw for intake manifold gasket change. Vibe should be running like a champ.
Re: tune up weekend
How did the gasket change go, and can you tell any difference since having it done? I changed mine, didn't notice anything different afterward. Well, after getting all the hoses reconnected properly I didn't notice anything. Definitely noticed a difference when I left one hose unconnected :(
biodieselrabbit
Re: tune up weekend
Post by biodieselrabbit »
I would also like to know if changing the intake manifold gasket produced any result. I know there is a Technical Service Bulletin on idle-hunting in cold weather but I thought that maybe changing the intake manifold gasket might be the real culprit. Has your vibe experienced this idle-hunting phenomenon before and/or after changing the intake manifold gasket?
2003 Pontiac Vibe
