Okay, so I've pretty much decided to keep my Vibe going on for another 3 or 4 years because of the way life is turning, my money will be needed elsewhere (apartment, marriage, rings, house savings, etc.). She only has 116k on it and a lot of life left.
Things I've done very recently: new brakes on all four corners (even new drums), new tires (assurance triple treads, second set, I like them), new serpentine belt, new plugs, new battery, etc.
Now, I want to make the car more exciting to drive (not that it isn't, but I need to keep it for a while longer). I'm also seeing on avg 28-30mpg of mixed driving. So I want to do upkeep to make sure I keep seeing that mileage.
The ideas:
1) I have to fix the window alignment on the drivers door.. it's folded up the weather stripping and it doesn't seat properly (water leaks in a little in car washes). Where do I find weather stripping for this? And is it just the regular fix that's in the sticky in the DIY section about pulling the door apart?
2) I want to install a CAI. I know it won't do anything for the mpgs, but I want it to have a little grunt to it.
3) I installed a new idler belt pulley, but I still have that "rattling" noise. I didn't do the full assembly and that's probably where I made a mistake, so I'm going to re-do it with the entire assembly and hope the god awful noise goes away.
4) I want to install a new PCV valve. I ordered one off of Amazon, and a different one from Vatozone and I have YET to get one that fits my vehicle. Both of them either have the wrong thread or the wrong depth or something. Idk. But I don't want to force the PCV valve in, and I can tell the thing is sticking even after all of the PCV valve cleaner soaking I can give it.
5) I hate the headlights. They suck, quite frankly. I want to go the HID route, but don't want to deal with disabling the DRL. I want to put HID fogs in instead, and I was wondering if anyone has any good recommendations for them?
6) New exhaust tip because the stock one is just.. well.. bland.
7) I want to paint the cladding black. I will use some sort of exterior paint and make sure it comes out nicely. My dad paints a lot of parts for cars and will help out. I will also pull the silly aluminum trim out of the car and paint it black and then put a nice clear over it so that it looks nice. I would body match, but my car is Lava and I don't want red pieces in the interior. Not my dig.
8) This will be my favorite piece of change. I want to make a custom "shield" for the front of the car so that the "nostrils" of the car are blocked off. I hope to shape it properly out of something like sheet metal to reduce drag from the air going into the bay. It's going to take some work, but I hope it looks good. Obviously I'd post pictures of this along with measurements for those interested. I wish I had my CAD program still so I can design it using that, but I'll draw up something. It will be flat black and hopefully glorious.
Now, I was wondering if there's anything else minor I can do to improve gas mileage or make sure I keep this thing running for a lot longer. I know, it's a Toyota motor so fantastic? Any tips are always appreciated. Sorry for the obnoxiously long post.
