quote:ullbergm:speaking of foglamps.Has anybody replaced their foglamps with the white or brighter bulbs?The owners manual doesn't say how you are supposed to replace them or what type of bulb..Yes I did replace the foglamp bulbs.Basically what you do is reach your hand under the front facsia near the foglamp. You will feel the foglamp assembly. Basically what you do, if I remember correctly is turn the drivers side assembly counterclockwise and pull out.The passenger side foglamp I believe turns clockwise, then pull out.I will confirm this unless someone else does first. Be careful taking the bulb out not to bang it against any part of the fascia and don't touch the bulb.
[Modified by NSimkins, 11:44 AM 8/6/2002]
