driver door interior panel access?
miksis
Post by miksis »
Greetings, All of my window and door lock controls have separated from the top panel. How can I gain access to the interior of the door panel and (hopefully) reconnect them?
MotoAce51
Re: driver door interior panel access? (miksis)
Post by MotoAce51 »
Take out the screws from door handle, and under the tiny cover of the latch handle. Check if there are any other screws. After you have all screws out just give a firm pull... It will pop off. I would suggest not doing it in the cold because the plastic could crack.
2004 Vibe Base- Injen CAI, 10,000K HID's, Projector Retrofit W/ Angel Eyes, Billet Grilles, Kicker KX6.5 Components, Helix TB Spacer, Pioneer Premier HU
miksis
Post by miksis »
My window and lock controls have disconnected from my surface controls. How can I access the interior to hopefully reconnect?
ParknVibe
Post by ParknVibe »
Quote, originally posted by miksis »My window and lock controls have disconnected from my surface controls. How can I access the interior to hopefully reconnect?I am having a hard time believing that the controls "disconnected" from the wiring plugs behind them.You have to give the forum what year the Vibe is. A 2009 model has three screws to remove before you can remove the door panel. The earlier vibes have two screws. One screw is behind the cover of the door opener handle. I can't remember where the others are.
DeClerq
Re: driver door interior panel access? (ParknVibe)
Post by DeClerq »
Quote, originally posted by ParknVibe »One screw is behind the cover of the door opener handle. I can't remember where the others are. The second one (on earlier Vibes) is at the bottom of the door pull. You'll also want to remove the little triangular trim piece up by the mirror. It just pulls out.
'09 Mazda5 Grand Touring'04 Vibe - M&T, Power Package, Protection Package
welcome to genvibeOne thread about how to remove the door panels is http://forums.genvibe.com/zerothread?id=24086Some people have had a problem where the driver's window/lock switch assembly has detatched from the silver trim piece and sunk into the door. from the slightly different desciption you posted in http://forums.genvibe.com/zerothread?id=46021 it sounds like that is the problem, and if so, then perhaps http://forums.genvibe.com/zerothread?id=45097 will be pertinent.
alex_nrv
Post by alex_nrv »
Vibe 2009+ or before?Maybe I am too late, but here it is... I did a little tutorial with pictures some time ago with my Vibe 2009.Enjoy!http://forums.genvibe.com/zerothread?id=44422
