Wobble at 80mph?
Nyx8
Wobble at 80mph?
Post by Nyx8 »
I have this problem when I'm on the highway I sometimes drive the same speed as everyone else without looking at the speedometer and end up going up to 80mph. Anyone else get a slight wobble after hitting about 80mph?I never felt this going the same speed in my GrandAm, Sunfire or Firebird cars in the past. Maybe it's the height of the Vibe?
~*Nyx*~
2014 Dodge Challenger SXT V6, approx 200 miles
SOLD - 2006 Pontiac Vibe Base 1.8L, 62k miles
SOLD - 1996 Pontiac Firebird V6, 94k miles
SOLD - 2004 Pontiac Sunfire 2.2L, 45k miles
SOLD - 1989 Pontiac Grand Am V6, 100k miles
ou.grizzly
Re: Wobble at 80mph? (Nyx8)
Post by ou.grizzly »
Dirt in the rims or tires need to be re balanced
Salsa Guy
Post by Salsa Guy »
Or maybe the Rotors are warped? You notice any vibration under hard braking?
Nyx8
Post by Nyx8 »
I don't get a vibration when hard breaking, I'll try to get it rebalanced and see how it goes. So it's not the wind affecting it huh?
~*Nyx*~
Re: (Nyx8)
Depends on where you feel the wobble. If it is in the steering wheel, most likely it is the wheels needing to be balanced. If the whole car is moving, then it could be the wind or other issues.
Bedlam
Post by Bedlam »
wheel balance, guaranteed.if your shop can't get it right, take em elseware.
07 1ZZ 5spd Stealth - Sold
03 1ZZ 6spd Shadow w/NAV - For Sale
06 AWD Stealth - Current
07 Magnum SRT-8 - Current
Salsa Guy
Post by Salsa Guy »
Sounds like a wheel unbalanced. Had some warped rotors on a car and when it got over 70mph it vibrated but it also vibrated under braking.
ehoff121
Post by ehoff121 »
Another $.02 - be sure to ask for "road force" balancing as the standard spin balance may not take care of your 'higher' speed balance issues.
Rodlucci
Re: Wobble at 80mph? (ehoff121)
Post by Rodlucci »
Balance is it!If the vibration is in the wheel it is in the front wheels and if it is in the seat it is in the rear wheels. Get a competent shop with good equipment to rebalance all four. Have them check to make sure none of your wheels are bent. If the balance does not fix it, tell them to do it again until it is right.
ramenboy...
Post by ramenboy... »
I agree w these guys... Did you recently have your tires changed? Or rotated?
de-badged o4 vibe
o2 triumph speed four
