To ground or positive?
ALs09
Post by ALs09 »
I found the wiring diagram for the turn signal/fog light switch (AllData) fog light wire #4 postion on the connector. Question is....... if I'm just wanting to and a switch (using factory wiring for adding fogs) one side would go to the fog light wire would the other side go to ground or to a positive? I know I'll need the relay also. Thanks much
09 charcoal, base, 2.4,17"alloys, just getting started
