52w head unit with 50w speakers, bad idea?
rgnjc
Post by rgnjc »
I'm looking at the Sony CDXGT56UI which is 52w, I have the M&T package. I don't know enough about audio systems to know if I should be concerned about the head unit putting out 52w with a 50w speaker set up. Can somebody enlighten me?
2005 Vibe base AWD w/ M&T, 191k miles (as of 8/2022)
2007 Vibe base FWS w/ M&T, 150k miles (as of 8/2022)
Wolfman213
Post by Wolfman213 »
You are fine doing that. 52W is peak per channel. Your RMS on that unit is only 17W. Unless you are literally running it full blast non-stop, you have nothing to worry about.
