Possible Transmission Noise
Jacob
Post by Jacob »
I have a 2004 Vibe with about 90,000 miles and a 5 speed transmission. I've recently been hearing a whirring click or rattle sound under certain circumstances. It seems to only occur in fourth or fifth gear when I'm giving it gas. I know these transmissions have bearing issues and I'm wondering if that is the cause.
Bedlam
Re: Possible Transmission Noise (Jacob)
Post by Bedlam »
Quote, originally posted by Jacob »I have a 2004 Vibe with about 90,000 miles and a 5 speed transmission. I've recently been hearing a whirring click or rattle sound under certain circumstances. It seems to only occur in fourth or fifth gear when I'm giving it gas. I know these transmissions have bearing issues and I'm wondering if that is the cause.If it is the dreaded bearing noise it will becomes audible in all gears in the not to distant future. It only occurs when you are loading the drive line under power. If you take it out of gear or feather the gas just right the noise will go away.Keep a close ear on the problem. It will get pretty loud before it actually goes. It will happen over a few thousand miles as well as it gets louder. If that time comes, a good shop can actually replace the bearing with the transmission in the car (will have to look since even most dealers and major shops have no idea how to fix it or won't). Other option is to get a junkyard transmission from a car a couple years newer to avoid the issue from re-occurring.
07 1ZZ 5spd Stealth - Sold
03 1ZZ 6spd Shadow w/NAV - For Sale
06 AWD Stealth - Current
07 Magnum SRT-8 - Current
