First post here guys, but always come here first if I have an issue. Could not find this addressed anywhere else. I have a 2003 Vibe GT with just the stock single CD radio and 6 speakers. At the recommendation of nearly everyone I talked to, I ordered my new receiver from Crutchfield. I followed the instructions and got it installed, and when I went to test it, all of the receivers operations worked (CD, tuner, etc.) but there was no sound coming out of any of my 6 speakers. I double checked the wiring harness to make sure all the colors matched and they did. Any ideas? Is the receiver I have putting out too much power for the stock speakers? Here is the receiver I have:Pioneer DEH-1300MP http://www.crutchfield.com/p_1...=5684
I had a friend with ford focus that did the same thing. Make sure the harness is correct as well. She needed a VW harness because the focus one was wrong. Besides that you need to make sure you have the remote turn-on wire connected to turn on the factory amp.
locate the remote turn on wire like he said. i had the same problem, that's what it was. your radio isn't telling the speaker amp located under the passenger seat to turn on.
The factory antenna and remote turn-on use the same lead. there will be a spot on the factory harness that has 2 black wires connected to the same pin in the harness, these are the antenna and rem turn-on.
