Hey folks,Yesterday I was on the lot of the local Toyota Dealer with a friend who was car shopping. I looked at a 2011 Toyota Matrix and noticed it had a stubby short antenna. A quick look over the other 7 on the lot showed the same antenna. I then went into the parts area and inquired and they said the short antenna was standard on all 2009-2011 matrix. The base looks about the same as the Vibe antenna base so I would think this would fit on just right on the Vibe. It looks like the Honda antenna several of you own but has a small antenna base that matched the antenna base on the vibeI did get the part number but cannot find the paper I wrote it in now Also the Suzuki Aerio Antenna will fit perfectlyHope this helps
Yeah, I always assumed the 09+ Matrix antenna was the same as the 09-10 Vibe, but discovered via Matrix Owners that it's actually almost indentical to the 7" Honda one myself and a few other Gen Vibers have. It seems kind of goofy that with everything else that's identical between the two, the antennas would be different . Go figure!
I think we all have the same concerns. It is difficult nowadays to find a good car dealer.Getting Toyota Camry cars in PA I really wanted a Toyota Camry because it is a very long lasting family car. We can get through anything with it. I struggled finding a Toyota Camry with everything I wanted. PA choices were hard to find. Even though the dealers may not all have the automobile I needed, they helped a lot. I found http://cardealexpert.com/model...Camry pretty fast. It has helped a lot. It' s like a one-stop site for all your auto concerns. You can also check it out.
