P0420 help needed
hahork
P0420 help needed
Post by hahork »
Sorry for the noob questions- Went to Autozone and got printout for CEL. I've seen a lot of p0420 posts on here, but looking for clarification. Is there a way to know for sure if the problem is O2 sensor (and if so, which one?) or the CC? Does anyone know the approx cost of replacing the CC? Any good mechanics in the Philly area?any help appreciated
keithvibe
Re: P0420 help needed (hahork)
Post by keithvibe »
only way to be sure it's the O2 is to use an oscilloscope on it. Any ASE mechanic should know how to use one. But then your paying their hr rate. Most just toss the 80 bucks at the new sensor but then end up getting a new Cat a few months later.
hahork
Post by hahork »
Thanks, guess there's no easy way around this. Has anyone cleared a CEL by cleaning the fuel system?
What year/mileage vibe do you have? I think the catalytic converter might be covered by the longer emissions warranty.
MarkM04
Post by MarkM04 »
I just got this code to.Since it's supposedly related to the catalytic converter, it should be the second O2 sensor, as the first one is way up on the exhaust manifold.From what I can tell, there's no sure way to diagnose this as either the cat or the o2 sensor. I'm going to try the spark plug anti fouler trick to see if that keeps the CEL off. It's a lot cheaper then an 02, and a heck of a lot cheaper then a cat.
lovemyraffe
Post by lovemyraffe »
P0420 could also be related to the intake manifold gasket, MAF...The best way to know for sure is to take it to a mechanic like keithvibe said.
hahork
Re: (joatmon)
Post by hahork »
sadly, it's an 03 with nearly 140k miles (and up till now, no real problems!)
DiveNut
Re: (hahork)
Post by DiveNut »
Betting it is your CAT. I threw the same code awhile back. 103K on my 2004. I ended up going with a direct fit, Magnaflow piece (part #93200). The local muffler shop knocked it out in 25 minutes while me and my kids waited. Total damage, $222 for the Cat + $75 for the install, $297 total. At least I don't have to stare at that damned CEL now.
Bare Bones Base, Abyss 2004 Vibe, Debadged, Auto, ABS, GM Performance Supercharger, Injen CAI, 2.3" URD Pulley, Unichip,Tru-Cool Tranny Cooler SOLD
1972 Plymouth Duster 340 (Strip/Street Project)
MarkM04
Re: P0420 help needed (MarkM04)
Post by MarkM04 »
Just to follow up on my anti fouler 02 spacer trick. Before my CEL would come on every 40-100 miles. After the spacer, it hasn't come on yet. It's been about 600 miles. So I think it's not coming bake.I don't have to pass emissions testing, so I'm not sure if your car would pass or not with this mod.
