USA Spec PA20GM for iPod use while keeping the factory radio
journeyforce
Post by journeyforce »
Folks,I just bought and installed the USA Spec PA20GM iPod interface in my 2009 Vibe. It works well in the car and is a nice alternative to the front jack. It has two modes. Mode 1 you control everything on the iPod by the factory radio. Mode 2 allows you to control the iPod from the ipod.I wanted the ability to use my iPod without resorting to a billion wires to play and charge the thing. I also wanted to retain the factory radio and the XM. This unit cost me $160 at Crutchfield (but can be found cheaper if you look) It plugs into the XM unit in the cargo hold. It took me 3 hours to remove the panels in the trunk and the floor on the right side taking my time(I did not want to go breaking crap) This works perfectly for the 2009-2010 Vibe with XM however there is one issue you will encounter. On the instructions it says to leave dip switch #2 off if you have a nav radio or on if you have the standard stock radio. This instruction is reversed, you need to turn dip switch # OFF if you have a non nav radio.Pros so farAllows control of the iPod through the radio and charges it thereby allowing you to get rid of the wires cluttering up your consoleCons so farThe instructions suck so you ether have to call the company to get the correct instructionsCheers
chlywily
Re: USA Spec PA20GM for iPod use while keeping the factory radio (journeyforce)
Post by chlywily »
Thanks! I have been looking for something like this and may give it a try.Also, just saw several listed on eBay for about $120 with free shipping.
Mark HjalmarsonGrand Island, NYOwner of two Vibes - '09 Vibe 1.8L and '07 Vibe 1.8L, both are pushing 100K miles and have been great.
journeyforce
UpdateI got the chance to fine tune my USA Spec install today. I originally had it so that the iPod connector was coming from under the center console on the passenger side. I was not happy with it like that so I routed it into the glove box and drilled a hole in that shelf above the glove box that I don't use and it is hidden when it is closed. I first bought a used shelf from a eBay seller and drilled into it(so as to have my original intact to return to stock if I needed to) I then used a GM PCV Grommet I got from the auto parts store to stick in the hole so the cable did not get snagged or skinned by the drilled hole. The Module is located under the center console under the cup holders and requires 1 minute to pull off and access.I will take pics of my set up in the glove box tomorrow or Thurs
