Driver Door Is Not Shutting! Please Help!
importiconep3
Post by importiconep3 »
A couple of days ago my car door stop latching on. I looked at the actual latch and is not stay on the lock position. There is a plastic piece under the latch that if i push the latch all the way back and push on it it remains on the lock position. I cannot find any information on this and 'am tired of having to use a belt to keep my door closed. Any information or dyi steps would be highly appreciated! Thanx
A Psycho Martyr
Re: Driver Door Is Not Shutting! Please Help! (importiconep3)
Post by A Psycho Martyr »
My sis-in -law (with a chevy cruze) just messed with her door and it atarted doing the same thing.My brother pulled the door handle as if he were opening it and messed with something and it worked. Door now closes.So if you're comfy trying just whatever, give it a shot.Pull the door handle out and try to flip the latch or something
Blueridge9
Post by Blueridge9 »
Check to make sure that all the BOLTS in the door jam are there and completely screwed in place.
Blueridge9 2004 Base, 1.8L "The Vibe is a melding of muscular looks, ..utility & economy, sportiness & road-hugging tractability." -Road & Track Magazine Sept. 2008 Pictures: http://s278.photobucket.com/user/blueridge9/library/" onclick="window.open(this.href);return false;
cq358
Re: Driver Door Is Not Shutting! Please Help! (Blueridge9)
Post by cq358 »
Pull the interior door release and see if the cam able to latch back into position. don't dry to jam the door shut while the paw is not in a proper latch position or else the latch palm/pin will be deform and cause more damage
Check the metal latch that the door locks to and make sure it isn't loose or has moved.
ou.grizzly
Post by ou.grizzly »
Go figure, for the last 3 months my 2009 AWD's rear driver door won't open from the outside or inside...
importiconep3
Re: (ou.grizzly)
The metal latch is all good. The thing that is happening is the latch on the door is not locking when the door is shut. I think it is some sort of spring that is not allowing it to lock. I am now searching to see what that actually part is called and get an estimate on it. Right now driving with a belt holding the door together, and getting wet when it rains. I have looked the part up and I believe it is $200 which is crazy.
jake75
Re: (importiconep3)
Post by jake75 »
Warranties ought to be 3 years or 36,000 miles whichever comes LAST!
09vGT
Re: (jake75)
Post by 09vGT »
Quote, originally posted by jake75 »Warranties ought to be 3 years or 36,000 miles whichever comes LAST!AMEN!
