Need help please.........
burrpenick
Post by burrpenick »
finding a pic of the inside of the drivers door lock mechanism. Have a new handle to install and its in the door fine, but cannot see how the ROD is supposed to be positions so that it somehow is moved by the lifting of the handle.George in NC
Re: Need help please......... (burrpenick)
no pics but hopefully something in this will be of some use
Attached files w040001.pdf (239.8 KB)
Wolfman213
Post by Wolfman213 »
For anyone who has done something to this extent to access the door locks, is it necessary to remove the speaker separately or can you leave it riveted in and simply disconnect it when you pull of the inner metal?
