05 Vibe front speaker trouble
05Vibe AWD
Post by 05Vibe AWD »
The left front speaker was blown so I put a set of Polk Audio speakers with a little box in and the sounded great.(not quite sure what the box is for but I was told to use it)Three days later both front door speakers and the sub quit working.Did the speakers ruin the radio or the amp I'm stumped.
hapagan
Post by hapagan »
that box is a crossover. it separates the highs from th mids and sends the different signals to their respective speakers. u might have had a bad conection somewhere or maybe the positive and negative wires for the speakers touched causing the amp fuse to blow. im not sure. do u have a M+T amp or aftermarket ?
04 Pontiac Vibe Gray, M+T package Custom Front Bumper Paint5% window tint everywhere except three front windows 12" Pioneer IMPP subPro bend bandpass boxBoss 1600w 4Ch amp6, 6.5 Infinity Kappa 62.9i 450w each
05Vibe AWD
Its the factory amp.I checked all the fuses per the owners manual and none were blown.I did'nt see a separate fuse just for the amp.
MotoAce51
Post by MotoAce51 »
Are you sure the crossover was connected correctly? High's to the woofer and lows to the tweeter could cause an issue. I would also check to make sure power is going into/ out of the crossover. That will narrow the location of the issue.
2004 Vibe Base- Injen CAI, 10,000K HID's, Projector Retrofit W/ Angel Eyes, Billet Grilles, Kicker KX6.5 Components, Helix TB Spacer, Pioneer Premier HU
05Vibe AWD
I did'nt hook the tweeters up to the crossover.There is no power to the crossover I tried a know good different speaker.
05Vibe AWD
I took the crossovers out and they smelled like they were fried.So I left them out.I removed the amp and jumped the wiring and could make all the speakers work.So the amp was fried put in a used amp $125.00 and it works great.So I'm thinking the crossovers fried the amp some how.
