Half of the year I use studless snow tires, so I decided to find a second set of wheels so that I didn't have to pay for mounting and balancing twice a year. Here's the rub: the lug nuts on the vibe have an extra long shaft that sits down inside the mounting hole. I've tried two different sets of wheels now (the first didn't have enough offset and rubbed the brake calipers) and had to get new lug nuts to fit. The new lug nuts don't have the same shaft, so there is a lot less thread-to-thread surface contact with the studs. I need to figure our a.s.a.p. if I should return these wheels and start from ground zero. Any ideas? I know I'm not the first person to deal with this, but none of the tire shops I've talked to have had much to say about it. The attached image is a picture of the new wheel mounted.
