2008 front brakes "click"
richard_v
Post by richard_v »
My front brakes make a clicking sound when I first back up and apply the brakes. Then again when I first apply the brakes when going forward. Almost sounds like there is too much play between the pad strong-back and the caliper supports (not sure what to call them). Anyone else have this happen? The dealer says there's nothing wrong... even after he heard it too.
bassplayaz06
Re: 2008 front brakes "click" (richard_v)
Post by bassplayaz06 »
re-torque your wheels. it's the rotor moving forward and backward. there's play between the studs and the rotor holes they go through, which makes it click forward or backward. put the torque up around 90 or so. if already there, go higher. this way the wheel holds the rotor. it just stops the clocking for the most part, and it's not dangerous, just annoying.
2003 Vibe GT, 1.8L, 6 speed Manual Lava Red 2 tone18" sport edition rimsCosmo CAIMy Garage http://forums.genvibe.com/zerothread?id=42483
Re: 2008 front brakes "click" (bassplayaz06)
90???
lovemyraffe
Post by lovemyraffe »
While I agree with your diagnosis, I don't agree with torquing the lug nuts to 90.
bassplayaz06
Re: 2008 front brakes "click" (lovemyraffe)
55 is a little weak... i'm used to puttin our cars up around 130 or so on the bigger cars. we put all the smaller cars at around 90 so the wheel actually stays on and grabs the rotors.
Kamikaze
Post by Kamikaze »
I want to say correct torque specs for our wheels is something like 79 ft/lbs.I usually torque to 85 ft/lbs.As for the click, get use to it. mine does it too, I remember a thread about this a long time ago, I thought it was the pads shifting in the caliper from fwd to rev, vise versa... I didn't think it was the rotor, but I could be wrong.
bassplayaz06
Re: 2008 front brakes "click" (Kamikaze)
yeah, the specs that came with the wheels i have said something like 55. after the first ride, we moved it right on up to 70 or 80
B14CK_H4WK
Post by B14CK_H4WK »
check your brake pads also they may be worn down too far and the clips are hitting your rotor
richard_v
Post by richard_v »
Thank you to everyone who responded. I will check the torque on the lugs. Now I'm smacking myself for not thinking of that before. Again... THANK YOU, Everyone!
