Want to install an amp and sub in 05 moon and tune???
7mac7
Post by 7mac7 »
Hi all, I'm having a little issue getting the info I need clearly. I want to connect and aftermarket sub-amp and sub. I get it that the black wire from the stock HU is the amp turn on. I will run my own 8 gauge power from the battery and and ground off the chassis. What is the best place to get to a set of signal wires? Can I take my signal from the stock subwoofer's speaker wires (at the box) or do I need to get at a signal pre-amp? If so which wires are the rear speaker wires (under the seat?). Could one of you all knowing Vibe Gurus pleas chime in on this for me?
"Do or do not, there is no try." -Yoda
papacueball
Post by papacueball »
If the amp will take a speaker level input, using the speaker wires for the sub would be the easiest thing to do. Sounds like you have a good plan already. Let us know how it turns out. Post some pics, too.
2009 Vibe GT - Carbon Gray Metallic - 5 sp. manualClarion-Sundown-Pioneer-Vifa-H Audio-Dayton-SDS
