How hard would it be to swap and retrofit an 08 instrument cluster into an 09?I know this wouldn't be a direct fit and the process would require some inventive mounting, but what would be involved in the electronic end of the project? Would I be rewiring the entire thing or just matching a few connectors?I would mainly want this done because I like the 08 style better than what I have now. If the swap would be too much of a pita, ill look into some custom faceplate options.
Quote, originally posted by Sublimewind »Could be simply a PNP thing..Could be a complete nightmare.. Maybe you get to be the first to find out.. cause I doubt anyone else has done it... im hoping for the first, expecting the second, and pretty sure on the third.
Quote, originally posted by DressedInBlack »I would mainly want this done because I like the 08 style better than what I have now. If the swap would be too much of a pita, ill look into some custom faceplate options.If you end up deciding to look into custom gauge overlays, I would recommend contacting Black Cat Custom. They do some amazing things with gauges .
