So has anyone ever replaced theirs? is it in the headlight relay or its own? I cant find a turn signal relay itself but I can find headlight ones.I suppose I should add info in. My sister has my vibe. She was driving, went to use a turn signal, heard a "clunk" like noise. Now the turn signals and hazards do not work. The fuse looks good, but theres a relay for it on the drivers side of the dash. Sounds like a good 1st thing to try fixing is the relay...
Haven't replaced on in a vibe, but should be a PNP part.. just swap.. whe you find it, there should be another like it you can swap and test, just to make sure..
turns out, the relay was not pushed in all the way. My dad looked at it, ordered the part then went to take out the old one (in the fuse box on the driverside inside the cabin, left side of the console thing) and found it was half way out. Pushed it in, all is working...huh weird.
