Headlight polishing
DeLaMano
Headlight polishing
Post by DeLaMano »
Hey everybody!I got a 2003 M&T a few weeks ago. It is in great shape inside and out, but the headlights were definitely showing their age. So I went to KMart and got a headlight polishing kit for $20 (plus there's a $3 rebate going on right now). After working up the nerve to purposely scratch up the lenses, I followed the directions and got some pretty good results. It is definitely better, but they're not crystal clear. I would recommend taking your time. Allow at least 2 hours from start to finish (masking to cleanup) for a good job.Here are the befores and afterses:
2003 M&T in Shadow145K ticktickticktickticktickticktickvalveclearance.
MotoAce51
Re: Headlight polishing (DeLaMano)
Post by MotoAce51 »
Pics not working. I tried this but got impatient and stopped. Now it wont stop raining and I cant start again.
2004 Vibe Base- Injen CAI, 10,000K HID's, Projector Retrofit W/ Angel Eyes, Billet Grilles, Kicker KX6.5 Components, Helix TB Spacer, Pioneer Premier HU
Apparently the forum software doesn't like https:// in IMG links, seems to auto rewrite it to be http://https://... anyway, the pic links work on http:// so here they are:Quote, originally posted by DeLaMano »
DeLaMano
Re: Headlight polishing (joatmon)
Post by DeLaMano »
@joatmon Thanks for getting my images up! I'll try rewriting the link without https...
Quote, originally posted by DeLaMano » Did I do something wrong in my post? nope, I'd blame it on the forum software. Your links were https, and apparently the forum software doesn't recognize that as the beginning for an image URL, so it put http in front of it, in a failed attempt to "correct" the link. Thats my theory anyway.
DeLaMano
Post by DeLaMano »
Okay, I guess that works. But now they're only showing up in your quoted post, and not in the original post even though that has been http'd. I'm confused.
right now the image links are showing up as http://https//lh6.googleusercontent.com ... 008.jpgyou would need to edit your post to make them look likehttp://lh6.googleusercontent.com/__ijbLU8p_B4/TahF03T2ZAI/AAAAAAAAAic/FlhqA_uvhQg/s400/IMAG0008.jpg(I'm only a user here, can't edit it for you)or you could get creative, glob them into a single image and upload it to the forumbtw, looks like the polishing made a strikingly effective change in the clarity of the plastic
silverbullet
Post by silverbullet »
Hey thanks for posting this up. Mine look just like your first picture. I wasn't sure if this would be the right solution because they don't look hazed over like my older cars I have done this too, just always look dirty. Now ill have to get around to this sometime
rAERRK
Post by rAERRK »
whats the cause of this? my cars almost 7 years old and the headlights still look new
MotoAce51
Re: (rAERRK)
Post by MotoAce51 »
I have no idea what causes this. One side of mine is perfect and looks new, and the other side looks like crap. Its smoked and blurry. I need to get back out and do it again. There are so many products out there and I have no idea which works and which dont....
silverbullet
3m makes a good kit ive used on other cars with nice results, you could try that one. ive always thought it was caused by sunlight damage. i heard a story that one guy wanted to protect the lens before that happened. put regular old sunblock on the lenses........ it melted them.
cptnsolo77
Post by cptnsolo77 »
Looks better! I used the Turtle Wax Headlight Kit. It comes with 3 pads, compound and lubericant. It comes out great, but you have to maintain it afterwards. Has anyone used the mothers powerball for thier headlights? I was thinking about using it with some lens compound to keep it clear ( like once a month ) Any users?
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
DeLaMano
Post by DeLaMano »
I used the 3M kit. They have refill kits, too. Again, TAKE YOUR TIME! I wish I would have not been so impatient. Someday I'll hit it again, but have more important things to focus on right now... Like aftermarket radio install.
(Double D)
Post by (Double D) »
Mine were hazed over horribly, They were pretty much yellow. So I busted out some 600, 1000, and 1500 grit wet/dry sand paper. Then broke out the Mcguires plast-x kit. They buffed out pretty much like new. As far as for what causes them to fog and haze, It's just oxidation/breaking down of the plasic by the UV rays, as well as exposure to salts and de-iceing agents depending on your location.
