I noticed today that while running I can take the key out of the ignition cylinder with ease. I know its not normal bit want to see if others have had the same issue. Thanks.
Hmm. Nope not mine. What year do you have?actully never had a car do that, in laws aztec has the opposite problem. Issue with the wiring in the shifter, always thinks its in drive and won't let the key out
Ha... I had a '80 Caprice that I could insert or remove the ignition key in any position for about 200,000 miles.Funny thing was that I could not turn the switch unless the key was inserted.The key was worn smoother than a baby's (removed).As to your problem .... what is the condition of the "teeth" of the key?
2008
47,891 Added new horns
69,036 Added sound deadening
70,395 Battery
its an 03 but considered an 04 and the key is kinda of worn a bit. but yea its needed to actual turn it initially but after that you can remove it in any position. huh. well its convenient to where if i have the car running and need to get something from the house i can just pull it out and use the keys with out shutting it down. but i just hope it doesnt go out anytime soon.
