No left side sound
Mr Magoo
No left side sound
Post by Mr Magoo »
I have a problem with the speakers on the left side of the car, front and back. I basically have a very weak signal. If I press my ear to the front left I can hear a little sound. I'm not sure anything is coming from the back. Original stereo had this issue and now the new one does too. Any ideas?
2007 Salsa base W/Cladding, 2008 Platinum base W/Cladding Picture: http://forums.genvibe.com/zero...).jpg
DoubleBaril
Post by DoubleBaril »
Do you have the moon & tunes stock amp? Maybe there's a problem with the left output on the amp?
2003 Vibe AWD
Sublimewind
Re: No left side sound (Mr Magoo)
Post by Sublimewind »
Quote, originally posted by Mr Magoo »I have a problem with the speakers on the left side of the car, front and back. I basically have a very weak signal. If I press my ear to the front left I can hear a little sound. I'm not sure anything is coming from the back. Original stereo had this issue and now the new one does too. Any ideas? What do you mean old and new? New aftermarket stereo or factory replacement? I would think it's a problem AFTER the unit, if it's done it with 2 different units..
Mr Magoo
Re: No left side sound (Sublimewind)
Post by Mr Magoo »
It is a factory replacement. Definitely after the unit. Bad ground? Never been wrecked.
DoubleBaril
Maybe the speaker wires themselves are grounded out somewhere.
2003 Vibe AWD
Sublimewind
hard to say.. about the only thing I could say would be to remove the HU and remove the speakers from the left side and ohm out the lines with a meter.. maybe there is a pinch on the wire?
Danielvis
Post by Danielvis »
I am having the same problem w/ 04 Vibe. No bass and very little volume from left speakers. Any luck on a fix?
Mr Magoo
Re: (Danielvis)
Post by Mr Magoo »
Well, it turns out both speakers were bad. Replaced both and now all is well.
