2009 Vibe - running new door speaker wire ???
dayday
Post by dayday »
So I set out today to install my new stereo goodies. All went well until I got to the doors. I've never ran speaker wire into doors before and just assumed I would find access to the rubber boot that the wires run through hiding behind the trim panel. What I found was one large white plastic wiring plug, doohhhh!!!Any suggestions? I'm strongly considering making an appointment to pay someone else finish this up. All I have left to do is run speaker wire and install the door speakers.
'09 Vibe 2.4L 5sp
SlammedNiss
Post by SlammedNiss »
Why run new wires into the door? OEM wiring should be fine unless you're going to run a high-output amp.
2011 Rav4 Sport
dayday
Re: (SlammedNiss)
Post by dayday »
100w to each door. I still have the factory stuff hooked to the new head unit for now.
'09 Vibe 2.4L 5sp
Sublimewind
Post by Sublimewind »
yeah, if you don't want to put with through the door, you can wire up to behind the HU and use the stock wires into the door.. Everything is becoming PNP, and the doors are a perfect example I see, a molex plug in the door jam (common over the years) so it's simple to plug it in and hang the door..
papacueball
Post by papacueball »
I think what the op is describing are all the connectors behind the kick panels, not molex in the doors (mine doesn't have molex). You can disconnect the ones that go to the doors, and pull the rubber boot out of the door jamb. Once you do that, you should be able to get the connectors to come through the hole where the boot was (one at a time). Then, pull your speaker wire out through the hole. You may need an electrician's fish tape or a coat hanger to pull the wires through the boot, as it's kind of crowded in there. Be careful not to poke holes in the boot. I fought with the driver's side for a while before I figured that out. The passenger side took only minutes to do.
2009 Vibe GT - Carbon Gray Metallic - 5 sp. manualClarion-Sundown-Pioneer-Vifa-H Audio-Dayton-SDS
