steering wheel replace
22lyons
Post by 22lyons »
just bought an 03 auto with 109k. the steering wheel is in bad shape with the rubber breaking down causing a bad rubber smell in the car. how easy is it to replace the wheel? any other thougths. thanks.
Re: steering wheel replace (22lyons)
Looks straight forward enough. I attached a PDF of steering column overhaul, pulling the wheel is only the first 5 steps.I haven't done it on these cars, but on some others, I have been able to just yank it off after removing the nut, and on other others I have needed to use a puller. The procedure shows using a puller.
Attached files w040001.pdf (187 KB)
lovemyraffe
Post by lovemyraffe »
It's fairly easy to do if you have a wheel puller. I have a spare steering wheel with the cruise control stalk on it if you are interested.
jkm311
Re: steering wheel replace (lovemyraffe)
Post by jkm311 »
This has to be the most concise fix to an intermediate-level repair I've seen in a while!Boom! Full directions with diagrams.Boom! Available steering wheel with cruise stalk.GenVibe, solving our small world's problems one thread at a time. Well done, Jared & Joat!
Steelies to the rescue.
22lyons
Re: steering wheel replace (jkm311)
Post by 22lyons »
thanks so much for your replies! what would you be looking to get including ship? thanks
lovemyraffe
Quote, originally posted by 22lyons »thanks so much for your replies! what would you be looking to get including ship? thanksHow's $40 shipped to you?
22lyons
Post by 22lyons »
in the mail
lovemyraffe
Thank you!
