Intake manifold gasket replacement
ktt88
Post by ktt88 »
Stopped by the toyota dealership the other day to pick up a intake manifold gasket for my 1zz 2006 vibe. When i got home from the dealership i realized i forgot to mention that it wasnt a gt model (2zz), so is this the right part for a 1zz?
Re: Intake manifold gasket replacement (ktt88)
I think you've got the wrong one!A quick google search for the part number 17177-0T020 says it's the intake manifold gasket for the 1.8 2ZR-FE for the 09-10 Vibe/Corolla/Matrix/XD and also the 2010 2ZR-FXE Prius.you need toyota part number 17171-0D020 http://www.dealerdirectparts.c...4.htm
ktt88
Post by ktt88 »
Went back to the toyota dealership today and the parts guy told me that 17177-0T020 is the red, newer, thicker design for the 1zz and that 17177-0D020 was the older, black, thinner design also for the 1zz. He reassured me that it was the correct part.
A Psycho Martyr
Re: (ktt88)
Post by A Psycho Martyr »
My uncle (Toyota mechanic) told me about the new design for the intake manifold gasket. Something to do with it drawing up a little when it gets REAL cold out. It was causing an idling problem. I don't know anything about the part numbers tho.
jasonvibe
Re: (A Psycho Martyr)
Post by jasonvibe »
my Toyota dealer got this in December for me for 1zz and had to wait 3+ days.part number 17171-0D020 As of then it was the latest. Anyone know absolutely for sure.. which is the latest gasket TODAY?
wallyuwl
Re: (jasonvibe)
Post by wallyuwl »
I got an intake manifold gaskeet from my Toyota dealer a few days ago and it is part number: 17171-22060. Made in Japan. It is sort of a rust orange color. They said it is the only part number available to them for an intake manifold gasket for the 1zz engine.
jasonvibe
Re: (wallyuwl)
Post by jasonvibe »
wow dealer by me ---ain't too swift. I tell him 1zz engine and he says he needs a VIN number. I tell him they are ALL THE SAME...corollla Matrix. He hates his own parts system. So the bulletin clearly states the 17171-0D020 is outdated. Now I'll purchase that orange one.17171-22060. Made in Japan . Yes,. It also follows the bulletin from 2007 . Now after the earthquake and sunami in Japan. Hope there's no issue getting it. This explains a lot. The dealer took 4 days to get it. I guess he was getting a discontinued part and the Toyota system does NOT "update". LASTLY, it better fix mine for good in the cold temps. It's warming up here and a final test may be 6 months away. Cannot believe I actually want cold weather. Thanks again.
Attached files Toyota1.8LM.I.L._ON_DTC_P0171,_AND_OR_PO133_ENGINE_RUNNING_LEAN_IN_SUBFREEZING_AMBIENT_TEMPERATURES_ (142.6 KB)
