Suspension noobie question
Gekko
Post by Gekko »
Noobie here around these cars. I have an 03 Vibe. Will a set of lowering springs from a 2005 toyota corolla fit on my 03 vibe?
Greg - Gekko
2003 Pontiac Vibe base 1zz-fe auto
ramenboy...
Re: Suspension noobie question (Gekko)
Post by ramenboy... »
Quote, originally posted by Gekko »Noobie here around these cars. I have an 03 Vibe. Will a set of lowering springs from a 2005 toyota corolla fit on my 03 vibe?better to match to a matrix than corolla. the springs should fit, but i think the spring rate might be different because the vibe's a heavier car than corolla...
de-badged o4 vibe
o2 triumph speed four
vibedrivermatt
Re: Suspension noobie question (ramenboy...)
Post by vibedrivermatt »
yeah I would try to check which brand springs the corolla has and then look at some charts from that manufacturer to see if the part number matches the 03 vibe. I just checked the TRD springs and theres different p/n's for 03 corolla and matrix/vibe. That was just TRD though maybe theres other aftermarket springs can be used on both?
BlueCrush
Post by BlueCrush »
Quote, originally posted by Gekko »Noobie here around these cars. I have an 03 Vibe. Will a set of lowering springs from a 2005 toyota corolla fit on my 03 vibe?Yeah, the Corolla has different weight ratios and spring rates. I would look at getting springs that were made for the Vibe or Matrix.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
audiovibe
Post by audiovibe »
They will fit but the money you will spend in replacement struts would kill you in the end. You could probably in the end cause damage to where the strut mounts over time if using the rolla springs. The only benefit would be the ability to have a lower stance. However the cons outweigh the pros by a mile. Your car could become very unpredictable.
