Running wire
Gordon
Running wire
Post by Gordon »
I just purchased a 2009 Vibe GT to tow behind my motoerhome. Does anyone know the easiest place to get through the firewall with some wire for rear lightsThanksGordon
keithvibe
Re: Running wire (Gordon)
Post by keithvibe »
main wire harness grommet
Gordon
Re: Running wire (keithvibe)
Post by Gordon »
Thanks for the quick replyCan you tell me where it is located. ThanksGordon
keithvibe
Post by keithvibe »
open your hood, look at the fire wall, you will see a massive bundle of wires going threw it... I'm not 100 positive on where the location is for the 09 and up.
wt2ga
Post by wt2ga »
Open Glove Box … remove it by releasing the stop travel arm on lower right …lift out and you will see the other end of the main wire harness grommet.
Gordon
Re: Running wire (wt2ga)
Post by Gordon »
Thanks alotI didn't look thereGordon
