Rear washer fluid works, front does not?
surbey
Post by surbey »
I want to start by saying I love Genvibe. I've gotten alot of great assistance here in the past; I hope I can get another :D.I noticed this last week that my front washer fluid no longer works. The blades go but fluid does not come out. The back one, however, works. Do the front and rear lines use the same pump? Any thoughts?
Re: Rear washer fluid works, front does not? (surbey)
welcome to genvibewhat year Vibe? I don't know about the 09/10 set up, but on the 03-08, front and rear have separate washer pumps, but both washer pumps get power from the same fuse (if the rear works and the front doesn't then its not a fuse problem)
scherry2
Post by scherry2 »
the '03 manual says they are separate pumps. which would cover the old body style i'm sure. the front pump is located in the side of the plastic reservoir the rear is in the front of the reservoir. have someone push the lever while you listen at the pump for a humming noise.
surbey
Post by surbey »
it's a 2004. I'll try that. I was worried it was the pump or it was blocked. Thanks guys.
scherry2
Re: Rear washer fluid works, front does not? (scherry2)
Post by scherry2 »
you probably can see it from underneath. with sheild moved
tribalman
Post by tribalman »
if you want more instructions do a search. i have a writeup on how to change the pumps out. 03-08 model.
None. Vibe is gone.
midnighthunder89
Re: Rear washer fluid works, front does not? (tribalman)
Post by midnighthunder89 »
Have you checked the fluid i know if mine gets to low the back will still work but the front wont.
2010 Vibe 2.4L 5 speed manual.
surbey
Post by surbey »
your writeup was AWESOME tribal, thanks for the assistance. I've now got another issue.I swear, this car is falling apart.
Vogel
Post by Vogel »
My front stopped working and there are 2 seperate moters so for now I just switched hoses from back pump to use as front pump took 5 mins. I will be replacing the broken 1 eventually but switching was just a quick fix for me Here's a link for instructions on an easy way to swap wiper motors. https://www.youtube.com/watch?v=o6eYxO6znuM
