shifting harsh, trans code 2716
mirage613
Post by mirage613 »
new member here, great site for info, somone please help. 05 vibe 1.8 2wd. the codes says it's a high pressure transmission selenoid. I also got the recall letter stating when the computer starts going bad one of the tell tale signs is it causes harsh shifting. could the computer be causing the code, or do i just need to have the selenoid replaced? thanks much.
keithvibe
Re: shifting harsh, trans code 2716 (mirage613)
Post by keithvibe »
It could be, it could also be as simple as the vacuum line has come off or broken off the solenoide
