Moonroof Rattle?
pjh
Moonroof Rattle?
Post by pjh »
The moonroof on my 2003 vibe rattles when I go over bumps. Anyone had this, or know how to fix it?
ehoff121
Re: Moonroof Rattle? (pjh)
Post by ehoff121 »
First thing I'd do is a visual inspection of the channel. Open the window all the way and then look from above for any debris.I found two mystery rubber pieces in my '05, about 1/4" long by 1/8" thick(rectangular) and they rattled around...
pjh
Post by pjh »
Ok, after a bit of a closer inspection it seems the rattle is coming from just in front of the moon roof, above where the sun visor sits. If I push up on the ceiling in that area the noise goes away. Maybe I need to take down the ceiling in that area, or just try to shove some foam in there from the moon roof?
Chango
Post by Chango »
Mine only does it when the visor is open and the moon roof closed. If I open the roof it goes away. If I close the visor it goes away.
Dragging Knee > Wheelies
pjh
Re: (Chango)
Post by pjh »
Unfortunately, this is the configuration in which I drive 95% of the time.
the_sarge
Post by the_sarge »
I had the same thing. I have my headliner out right now working on a moonroof leak. I found one of the mounting nuts on the moonroof assembly itself loose. I never would have found it without taking the headliner down though. That's not too hard a job, there's a post on here telling how to do it step by step.
pjh
Post by pjh »
Thanks, I'll have to get around to looking into that soon.
