Steel or metal valve stems for winter tires?
vit
Post by vit »
Ok, shopping for winter tire and steel rim package at Tirerack. Thinking of going with 195/60R16 Bridgestone Blizzak WS60 Blackwall tires on steel rims. I figure these should work better in snow than 205's. What should I do for valve stems? Metal or rubber? The TPMS sensors are only 136 bucks if going with rubber and I was almost thinking of getting them, they are twice the price with metal stems. Maybe I should just put up with the low pressure light? Decisions...
lovemyraffe
Re: Steel or metal valve stems for winter tires? (vit)
Post by lovemyraffe »
Even for $136, I would put up with the low-pressure light. I don't have the sensors in my wheels and put up with the light all the time anyway. You could always put a piece of electrical tape over the light to cover it.
vit
Post by vit »
I'm leaning towards just skipping them. The total w/o them would come to $644.80 minus the $50 gift card. Not too bad.
vit
Re: (vit)
Post by vit »
What about the stems?
areles
Post by areles »
Skip 'em!
lovemyraffe
Re: (vit)
Quote, originally posted by vit »What about the stems?I don't know. I'm not much of a tire expert. I just use whatever happens to be put on, I don't know if it makes that much of a difference.
Re: (lovemyraffe)
Don't waste your money on the TPMSs. If you get them in your winter wheels, the ones in your 18s will have to be re-programmed (by the dealer) every spring and the ones in the winter wheels will have to be re-programmed (by the dealer) every fall. My mom and I got 16" steelies for our '09 GTs last winter and the light being on is not a big deal. After a week or so you won't even notice it anymore .
vit
Post by vit »
Well, the tires and rims are ordered. Should be good to go.
Re: (vit)
metal valve stems are harder to slash... If you happen to live in that kind of neighbourhood!
