quote:I do have some minor suggestions:As my car had spent a winter in Eastern Canada, rust had camouflaged the 6 mm Allen socket in the anti-roll bar link mount, so I struggled with vice grips, etc., to prevent the stud from turning as I unscrewed the nut. A mention of same might save someone some grief. (Likewise the fact that the same size socket is found in the top of the rear strut shaft, to prevent it turning as the nut is loosened)I found it was better to break loose the 17 mm shock top nut before removing the strut, as it was hard to hold the top flange on the bench. (with an air wrench this would not be problem, but not all of us are so-equipped)Neither Tein's nor your instructions address the fact that when you cut the rear rubber, it loses its press fit on the shock shaft, and so it and the plastic protector slide downwards, exposing the shaft to road debris.(see pix 24 & 29) This may not be an issue, and if not, the instructions should say not to worry about it. Just to be safe, I bonded it to the upper seat with weather strip adhesive. It would be useful to include torque specs for all fasteners, as the big knuckle to strut bolts are probably often under-torqued, and I know a couple of people have over-torqued and stripped the 12 mm front upper mount nuts. (not to mention wheel nuts!)I eye-balled the camber and toe-in before and after and decided it was close enough, but a comment on whether re-alignment is unnecessary, advisable or mandatory would be appreciated.Thanks again for the straight and simple story!Regards,Bill
Ballbilljan.ball@sympatico.caI did have air tools, so that helped a lot removing the real tight bolts. If you don't have the air tools, you can always use what I call a "cheater bar". Take a longer metal pole and place it over the handle of the wrench you are using for more leverage. Also, in breaking loose that top nut on the rear strut tower you mentioned... I placed the strut on the garage floor, put the allen key in the bolt, and held it to the ground with my shoe. then I just cranked on the bolt until it came loose. Once that sucker gets loose, she's easy to take off.I haven't gotten an alignment yet as I am getting new rubber to replace those AWESOME Conti's (sarcasm people). I figured I would wait since I haven't noticed any pulling, bad steering or such.
