Adding a snow plow to my Vibe? Good idea?
bobpage
Post by bobpage »
Preparing for the winter. I am considering adding a snow plow to my Pontiac Vibe. Would this work? I found this website promoting a reversible snow plow called SnowSport 180, it has a couple pictures and a video with a Pontiac Vibe plowing some snow. I am trying to do some research before spending 1000 bucks on plow, and I am just curious if anyone have any experience with SnowSport plow? Check out their video, and images here:http://www.buysnowsportplows.c...rt180I have also attached an image I found on their website:
djkeev
Re: Adding a snow plow to my Vibe? Good idea? (bobpage)
Post by djkeev »
CAN you? Yes.SHOULD you?NoI could go into the why here but there are many reasons on the internet. Basically you have a car WITHOUT a frame. Snow plowing really beats up a vehicle, to the point of distorted a heavy steel frame at times. Any truck used to plow snow is most often "beat". The entire suspension and drive train have been pushed to the operating limit greatly reducing the life of each component.You've got a light tin box designed for high MPG's, there is no inherent strength in the unibody for plowing. They barely have the strength to pull a light trailer!Really think this one through.The ONLY way I'd say "yes" is if you live in an area that gets an inch or so and you basically want to "sweep" off the driveway. Even then, you'd be tempted to move the heavier stuff should it fall and you really shouldn't.Dave
(o ! /o) (o)=I=(o)
DressedInBlack
Re: Adding a snow plow to my Vibe? Good idea? (djkeev)
Post by DressedInBlack »
Quote, originally posted by djkeev »CAN you? Yes.SHOULD you?Nox2,3, and 4
http://
keithvibe
Post by keithvibe »
this won't work on the vibe... you won't be able to find a 2" receiver for the vibe unless they make an adaptor to inlarge from the standard vibe sized hitch to the 2" hitch
KNINE
Post by KNINE »
I don't think your transmission would like it.
06pvibe
Post by 06pvibe »
REALLY bad idea. It's not such a great idea on a vehicle that has a frame let alone one with a uni-body.Ever hear the expression, "Don't ever buy a truck or Jeep that has been used to plow snow with." Well, I worked for Jeep for nearly 5 years and can tell you first hand that plowing snow takes it toll on any vehicle.It would be cheaper in the long run to contract someone that has a vehicle w/a plow and hire them to beat the sh*t out of their vehicle.
06pvibe
Re: Adding a snow plow to my Vibe? Good idea? (keithvibe)
Post by 06pvibe »
Quote, originally posted by keithvibe »this won't work on the vibe... you won't be able to find a 2" receiver for the vibe unless they make an adaptor to inlarge from the standard vibe sized hitch to the 2" hitchThey do. (1-1/4"-2") And they are not such a good idea either.
I'd say drop the thousand dollars on a snowblower instead of a vibe plow
ou.grizzly
Post by ou.grizzly »
Used lawn tractor and blade and or blower attachment.
midnighthunder89
Post by midnighthunder89 »
you could buy a ****ty pickup with a plow for like 500 ya it will be rusty but it would get the job done if you have a really big driveway. otherwise I would say snowblower, or lawn tractor.
2010 Vibe 2.4L 5 speed manual.
Whelan
Re: (midnighthunder89)
Post by Whelan »
I love my snow thrower. 28" dual stage Craftsman with electric start.
2012 GLI Autobahn 6MT
bobpage
Post by bobpage »
Thanks for some good answers, I got convinced not add a plow to my Vibe. I already own a snowblower, but I was getting tired of walking out in the cold and having the snow blowing everywhere, and was thinking it might be nice to sit inside a warm car. I might use my snow blower another winter or trade it in for an used ATV with snow plow (it wouldn't be as warm as the Pontiac Vibe), but ATV snow plowing, looks a lot more fun than using a snow blower. http://www.buysnowsportplows.c...rtatv
KNINE
Post by KNINE »
You need a teenager to do that for you.
kowell
Post by kowell »
Quote, originally posted by djkeev »CAN you? Yes.SHOULD you?No.Should you take pictures during and after if you ever do it?HELL YEAH!
Re: Adding a snow plow to my Vibe? Good idea? (kowell)
Take the thousand and have a nice little vacation somewhere warmer!!!
