Dupli-Color Perfect Match - Pewter Metallic ( 11WA382E ) Replaces T408. I tested on a peice of scrap plastic & it is just a bit glossier than the factory paint, but the color matches perfectly. These are the silver-ish panels in the interior by the way. When the wheather cools off in a couple of months im going to repaint all the panels. Too damn hot here in South Florida LOL. They have a lot of scratches on them and are very worn around the door lock buttons....seems like the previous own was rough or had some sharp fingernails.Oh yeah, bought it at Advance Auto for about 8 bucks.
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
So mine weren't as worn out as yours since my Vibe is a base with no options at all ( ) but they were showing SOME signs of wear. Do you plan on using a clear coat when you repaint the trim? And also do you plan on doing inly what NEEDS it, or all of it so it all matches perfectly?
Definitely a clear coat & yes I will paint all the panels.
