Is there such a thing as ...
BlueCrush
Post by BlueCrush »
A chord that has a USB plug on one end and a 3.5MM female plug on the other end? I searched the interweb but came up empty.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Wolfman213
Post by Wolfman213 »
Something like this? http://accessories.musiciansfr...32600Not sure exactly what size the "mini" is that they are referring to, but I think that looks about right. If not I'm sure you can get another adapter to convert to the correct size.
BadBrew
Re: Is there such a thing as ... (BlueCrush)
Post by BadBrew »
2005 Lava Vibe base Garage
ParknVibe
Post by ParknVibe »
What is each end being plugged into? Or used for? If it is used for audio transfer to and from a stereo and a computer, then there are USB electronic devices for that. Normally it will come with a male 1/8 stereo plug or RCA plugs. Females are always on the radio or stereo.With a USB setup, there is always a electronic converting of the siginals unless it is all digital. analog to digital. visa versaWith an Apple Ipod just use a male to male 1/8" stereo wire for the car radio from the ear jack.Else I don't know what you need it for. However, I wish the 09-10 Vibe had the USB or the special Apple plug connection.
BlueCrush
Re: (Wolfman213)
Post by BlueCrush »
Quote, originally posted by Wolfman213 »Something like this? http://accessories.musiciansfr...32600Not sure exactly what size the "mini" is that they are referring to, but I think that looks about right. If not I'm sure you can get another adapter to convert to the correct size.That's too big and expensive for what I need it for. Thanks, anyway.Quote, originally posted by BadBrew »this ?http://compare.ebay.com/like/1...=sbarPerfect! that's exactly what I'm looking for. Thank you. Just bought one. Quote, originally posted by Ivibe »What is each end being plugged into? Or used for? If it is used for audio transfer to and from a stereo and a computer, then there are USB electronic devices for that. Normally it will come with a male 1/8 stereo plug or RCA plugs. Females are always on the radio or stereo.With a USB setup, there is always a electronic converting of the siginals unless it is all digital. analog to digital. visa versaWith an Apple Ipod just use a male to male 1/8" stereo wire for the car radio from the ear jack.Else I don't know what you need it for. However, I wish the 09-10 Vibe had the USB or the special Apple plug connection.Its for direct connecting my Palm Pre Plus with my head unit, for Pandora listening pleasure w/o using bluetooth. Listening to Pandora via bluetooth, sound only comes out of the front speakers. I'm hoping this will fix it so sounds come out of all speakers. Thanks!
My Fleet:
ponta2147
Re: (BlueCrush)
Post by ponta2147 »
Quote, originally posted by BlueCrush »That's too big and expensive for what I need it for. Thanks, anyway.Perfect! that's exactly what I'm looking for. Thank you. Just bought one. Its for direct connecting my Palm Pre Plus with my head unit, for Pandora listening pleasure w/o using bluetooth. Listening to Pandora via bluetooth, sound only comes out of the front speakers. I'm hoping this will fix it so sounds come out of all speakers. Thanks!Pandora in your car!!!!!! I have that app for my Motorola Backflip, why didn't I think of that!?
BlueCrush
Re: (ponta2147)
Post by BlueCrush »
Quote, originally posted by ponta2147 »Pandora in your car!!!!!! I have that app for my Motorola Backflip, why didn't I think of that!?It's great for long road trips...like going to Indy and back.
My Fleet:
