How do you know if you have the C59 or C60 transaxle?
mntn-biker
Post by mntn-biker »
As the topic says, How do you know if you have the C59 or C60 transaxle? I am replacing my 5 speed with a 6 speed (from a Corolla) and am looking to drain and refill the replacement tranny with Mobil 1 SAE 75W-90 GL-5 gear oil and see that the repair manual capacity states:C59 1.9l/2.0qtsC60 2.3l/2.4qtsThe manual says the housing is stamped near the top with the C59 or C60 but all I can find is a 7 or 8 digit number (can't remember offhand) but nothing that says C59 or C60.Anyone know if possibly the C59 is the 5 speed and the C60 is the 6 speed?????????Just looking to findout upfront if I buy 1 or 2 qts of the gear oil.Thanks - MikeON EDIT: I did some Googling:C59 = 5 speed MTC60 = 6 speed MT
2003 base model
Re: How do you know if you have the C59 or C60 transaxle? (mntn-biker)
C60 is the 6 speedhttp://www.vibratesoftware.com...s.htm
any MT I've had used the same change procedure.open the fill holeopen the drain holeclose the drain holefill through the fill hole until the level reaches the bottom of the fill hole (when it starts to come back out of the fill hole)close the fill holebuy three quarts to be sure
