fuel pump assembly
tdruber
fuel pump assembly
Post by tdruber »
The past few weeks My '05 base model Vibe has been taking a few seconds of cranking to start, but has always started, so I didn't worry too much about it. This past Friday my CEL finally came on, went to AutoZone and was told that it's a P0171 code. It seemed safe to drive home. Saturday morning the car died on my way home from an errand. We've tried cleaning the MAF sensor as suggested on a previous thread on this site. No luck. We even replaced the MAF sensor, no luck. Spent several hours trying to diagnose ourselves and we think we've determined that the fuel pump needs to be replaced. I purchased the fuel pump and strainer from AutoZone this evening and compared it to what was pulled from the vehicle, it's clearly not the same part. Is it possible that the previous owner (or his mechanic) put the wrong one in and the car was still able to function? Any suggestions?
Re: fuel pump assembly (tdruber)
did you take (or could you post up) pictures of the one that was in the car and the one you got from AutoZone?
tdruber
Re: fuel pump assembly (joatmon)
Post by tdruber »
This is the whole assembly that we pulled out of my car.
tdruber
Post by tdruber »
Here's the fuel pump
tdruber
Post by tdruber »
And here is what I assume is the strainer [IMG][/IMG]
tdruber
Post by tdruber »
Sorry for the multiple posts, I don't know how to insert the image so that it just appears in the post. Also here are the links to the AutoZone website with pics of the parts I bought (and returned) last night:Fuel pump:http://www.autozone.com/autozo...earch Strainer: http://www.autozone.com/autozo...8vd30
keithvibe
Post by keithvibe »
have a look here.. this is for a celica but it should help youhttp://www.newcelica.org/forum...unt=1
Does the replacement fuel pump fit and hook up to the housing, strainer as well?
