Driver's door trim plate
lightsup
Post by lightsup »
I need a new trim plate for my driver's door. The controls for my windows and locks work fine, but two of the tabs on the back of the trim plate got broken off, so it's not sitting securely in the door.I have a 2005 Vibe AWD. I see it here for like $40 ($55 with S&H), but that seems pricey. http://www.trademotion.com/par...gid=0Will the Matrix part work instead? It's here for like $18.http://www.toyota-parts-dealer...39087/I'm also not sure what the "one touch" thing is on the Matrix. Any ideas?
A Psycho Martyr
Re: Driver's door trim plate (lightsup)
Post by A Psycho Martyr »
Should be the same piece. I'm also not sure about the one touch thing tho.There are a few Matrix Owners amongst us so someone will chime in soon I'm sure
lightsup
Re: Driver's door trim plate (A Psycho Martyr)
Post by lightsup »
Maybe I should order them both and return whichever one won't fit.
Bodok
Post by Bodok »
Old thread but I am having the same issue with the drivers sided trim plate. Did you find out which Toyota part is correct, the one w/one touch or w/ out one touch.
Thanks,
Brock
Bodok wrote:Old thread but I am having the same issue with the drivers sided trim plate. Did you find out which Toyota part is correct, the one w/one touch or w/ out one touch.
Thanks,
Brock
welcome to genvibe.
I can't answer your question, but I used the trick in viewtopic.php?f=28&t=36996" onclick="window.open(this.href);return false; on mine
based on the picture at http://www.ebay.com/itm/Toyota-Matrix-M ... 57&vxp=mtr" onclick="window.open(this.href);return false; it looks like the toyota part number is 74232-01030 . A google search for that part number turns up lots of sources. They don't spec shipping costs, but maybe you can find a good deal. One indicates that there is an updated part 74232-01030-B0, don't know what might be different about that
