Catalytic Coverter, loss of oil
Asweet
Post by Asweet »
I recently brought my 2003 Vibe to a dealer. They have replaced two O2 sensors, and now replaced a catalytic converter. Whe I picked it up ther was a loud noise. They checked the oil and early that day it was full but now is 3.8 quarts short of oil and there are no oil stains on the dirveway or garage floor.Has anyone experienced this problem or know of any issues with the oil disappearing?Thanks
cptnsolo77
Post by cptnsolo77 »
Welcome to GenVibe! I see your in FL as well ! Im curious as to why the O2 sensors & cats were changed. Were you getting a check engine light? As far as the loss of oil, does the dipstick show a mix of coolant & oil? How does the inside of the tailpipe look? Does it have a lot of soot on the inside? If you have a loss of oil, but no visible leaks it has to be burning off somewhere.
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
engineertwin2
Re: Catalytic Coverter, loss of oil (Asweet)
Post by engineertwin2 »
Quote, originally posted by Asweet »They checked the oil and early that day it was full but now is 3.8 quarts short of oil and there are no oil stains on the dirveway or garage floor.This is a big problem as the engine only takes 4 qts or so. Ultimately, it could require the shop to tear down the engine. Check the coolant to see what color it is - if its muddied, that could be where your oil is going. You could also be burning it. Are you noticing blue smoke? There are so many ways to lose or burn oil it's difficult to diagnose.
millster
Post by millster »
I'd definitely be looking into the likelyhood of it burning oil. If your cat and o2 had to be changed, there's a reason. If you're burning through that much oil, that's probably your reason.Best of luck and be sure to keep us posted!
-Millster-
2006 Toyota Matrix XR
1995 Saab 9000CSE 2.3T
fss106
Post by fss106 »
this may be a bit blunt and obnoxious but-- have been doing oil changes regularly?
'03 Vibe GT (manual/6 speed)
