At some point this is going to be needed!!! And judging by the two threaded holes below it, yours might not be as easy to get to.....It also appears that there's an access to an oil passage and to the right behind the black wire is the coolant temperature sensor. Not too sure what that big black connector is for...The attachment is a much bigger version of the same pic!
