Lowering springs for 09 vibe
muchvibe21
Post by muchvibe21 »
Any advice or suggestions on lowering a base 1.4 l vibe? what type of springs and how low should i go? thanks!
Re: Lowering springs for 09 vibe (muchvibe21)
First, the base Vibe is a 1.8L not 1.4L .Second, search around this (Handling, Suspension & Brake) Forum and you will find plenty of info on what springs will work and what people have used on their '09-'10 base Vibes. Since you have a base you can use anything that's available for a Matrix so you can also check out Matrix Owners for info as well.
