aftermarket hatch release
Socks
Post by Socks »
Ok, so this always kinda made me angry about the vibes in that some of the things like this are not standard. That said, most of the power options have been remidied. What Im looking for is to see if there is any way to wire up a hatch realease for my '04 vibe. I have remote locks and power windows but im trying to wire up a rear hatch release and have the button up in the dash. Any help would be great on some ideas
Bastranz
Re: aftermarket hatch release (Socks)
Post by Bastranz »
Do you want the whole rear hatch to open, or is the glass sufficient? If the latter, holding down the button by the dashboard should work, although it seems to stick on my Vibe.
AdmRose
Post by AdmRose »
Honestly never understood the desire for this on the Vibe. I rarely use the hatch glass unless I'm already outside the car (in which case the fob is fine). If I want to open the hatch I just unlock the doors and go open it.
2004 AWD Vibe - "The Indignant"- Traded in 7/9/12
2010 Honda Insight EX - Current ride
cptnsolo77
Post by cptnsolo77 »
Same here. The only time I use the hatch glass is when I air out the car when Im inside the house. I usually tilt the sunroof & pop the hatch glass. Its not like im going to drive with the hatch glass open lol.
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
audiovibe
Post by audiovibe »
I think the only time I open mine is to clean under the glass; it gets really dirty under there somehow.
Socks
Post by Socks »
no, im looking for the whole hatch to open. Like I said, I dont have power anything on my car so I dont have any dash buttons for it
scherry2
Re: (Socks)
Post by scherry2 »
I'm sure ebay has an accuator that you can pop rivet in and hook to the rod going to the latch OR go to a junk yard and remove the accuator from a crunched vibe that has one OR contact David Hawkins on this link http://forums.genvibe.com/zerothread?id=37786 and see if he has one with the switch. then just wire it in.
A Psycho Martyr
Re: (cptnsolo77)
Post by A Psycho Martyr »
Quote, originally posted by cptnsolo77 » Its not like im going to drive with the hatch glass open lol.I do! I love having all the windows down, radio all the way up, and that back glass open. It rocks
VibeBear
Post by VibeBear »
Any stereo shop in Edmonton should have a universal fit actuator that they'll sell you. Should run $15-20. If you want to be able to either lock or unlock from the dash, you'll need a rocker switch similar to this:http://www.rvandvansurplus.com/eshop/pr ... .jpgYou'll also need 2 relays & wire them like so:
1992 Chevrolet Camaro RS 305/5-speed, Bright Dark Teal
2009 Pontiac Vibe Base 1.8L/5-speed, Carbon Grey
Socks
Post by Socks »
thanks for the info bear, its much appreciated on how to set this up man
